Z400 Blown Up
Old Jun 15, 2016 | 09:49 AM
SuzukiGirl's Avatar
Default Z400 Blown Up
Hey yall! I have a Z400 that is basically ruined due to getting dirt in the motor.. I know it won't be cheap but can someone break down everything I will need for it! I know basically everything that moves needs replaced
Old Jun 15, 2016 | 09:59 AM
Fasteratv's Avatar
It's not cut and dry what you will need until it's torn down. But the basics would be piston and rings ( and possibly a bore ), top end gasket set, oil change, maybe a shim kit to properly adjust the valves, and determine the reason dirt got into the engine and remedy ( running without an air filter ? )
Old Jun 15, 2016 | 05:15 PM
Eisenpforte's Avatar
How did you get dirt in the engine? I had a Z400 and it seems like that would be tough to do.
Zephead98
May 31, 2016 01:26 AM
Chris.400
May 27, 2016 08:17 PM
R.J.
2) Chassis problems..
12
Apr 2, 2016 01:15 PM
grangerboy
Mar 29, 2016 10:21 PM
