How to Cross a BIG Washout
#21
#22
One of the trails we used to ride a lot hasn't been maintained by any club or the state for years and years. My friends and I cleared out some of the overgrowth with machetes, axes, and saws. We all worked on it for several hours. We may have gotten 1/2 mile of it fixed up nice. Since we can now ride the roads in that county, we take the roads to other parts of the trail, or to a different trail altogether.
#23
First I'd like to thank you folks for taking the time to describe some of the techniques for traversing a washout.
I guess the bottom line is "don't do anything you aren't confident you can do." I was looking at the drainage ditches on the dirt roads around my neighborhood. They can be 2 foot deep in spots. They are manmade washouts. So I tried to envision how I would drop my ATV into these ditches and climb out the other side. I think going more straight in, not at very much angle at all, is a better approach if I'm confident the tires will hit the other side before the nose of the machine. And then just enough throttle to start to climb out the other side while the rear tires hit bottom, and the fronts are clawing their way up the other side. I think I will be leaning over the handle bars to transfer some weight to the front of the machine.
As many of you know, I've whined before about all the horsepower our machine have. Yesterday I opened the throttle on my 1000cc machine on my driveway and felt the front of the machine get light. It was fun, sure. Horsepower is what makes our ATVs fun. I perceive it pretty easy to do a "wheelie" and flip over if you don't know what you are doing. Climbing out of a washout greatly exacerbates this condition with much weight transferred to the rear of the machine. That's one reason I bought a "long wheel base" machine (2 up); for more stability on steep inclines. Mine has a long 59" wheelbase.
Does that sound like a reasonable riding technique for crossing a washout? I guess I will learn how to do it by just doing it. Start small and work your way up.
David
PS jumbofrank: It's great to here you participate in ATV trail maintenance. The clubs around Colorado do the same thing. I need to join one. I'm more than happy to help maintain our trails but I haven't done squat yet.
David
#24
#25
You are absolutely right Zrock. I bought this machine because I liked the color. And luckily it comes with a "detune" key that limits the horsepower to about half I'd guess, but don't know for sure. That is the key I use most of the time.
In my sports car days we used to say it was most gratifying to drive a small car fast. I had great fun with my 50 horse Sprite and my 90 horse Lotus. Even my 80cc two stroke Bridgestone "dirt bike" was great fun. Some WOT experiences in these "lesser" machines is thumbs up.
I was advised to get a "big bore" machine as the air is quite thin at 10,000 feet and can zap 30% of the engines horsepower. One of my buddies remembers riding a "350" cc size ATV and it didn't have enough umf to pull him up and over a rock field. He bought a 750 the next time. Someday there may be small turbos on our engines so we don't loose power at high altitudes.
Learning a variety of trail riding techniques for this rookie is why I started this thread.
David
David
#27
David
David
#28
Agree that it is not the same as a carb but power is still robbed with FI at altitude. Even if the ICE was force induction, it helps but power still gets robbed at altitude. On my Grizzly, I've actually got a fuel controller along with an AFR meter so I can tune while under load and make adjustments for the altitude.
#29
No matter what, the air gets thinner at higher altitude. Less oxygen and less fuel to burn with it makes less power, about 3% for each 1,000 feet. But if the oxygen sensor is working right, EFI keeps everything running smoothly up to at least 10,000 feet. A carbed 350 that's not jetted for the altitude would really suffer. And if it was jetted for 10,000 feet it wouldn't run right at lower elevation. It's around 750 feet here, and I had an ATV trip to Utah planned years ago. I would have had to get my carb re-jetted if I didn't have to cancel my reservations for medical reasons.
