1998 Kawasaki Bayou 220 starter mounting
Old Oct 19, 2018 | 05:45 PM
Stephen Ayers's Avatar
Default 1998 Kawasaki Bayou 220 starter mounting
Thanks for sharing some information in advance. I have removed a starter from a 1998 (vin 'W') from a 220 Bayou. I wire brushed clean the starter area, sucked it out with a vacuum sweeper. Installed the new starter without bolts. There is spacing under the starter mounting flange and the engine block. I installed the bolts, put some torque on the bolts. The starter will not pull that far. I pulled the new starter out, installed the old starter, and the spacing is between the starter mounting flange and the engine block. Owner says the starter has been replaced twice already thru the years. Front bolt was loose on old starter upon removal. I have checked the starter motor number on the box. By the box, it is correct and the starter does appear to be the same as I have removed. Is there a washer or plate that goes under the starter motor flange and block to take up this space. Spacing is about .070" thousands of an inch if starter is pushed down on one side. Anybody ever seen this? Thanks again in advance for any information.
Arkansas,Paron
Sep 17, 2018 01:57 AM
Arkansas,Paron
Nov 4, 2014 05:30 AM
ggagnier
Nov 9, 2011 09:20 AM
bks321
Dec 22, 2004 09:34 PM
Nathan Poe
Apr 26, 2004 08:24 PM
