Tracking / steering issues
Old Aug 27, 2019 | 06:03 PM
bradleyheathhays's Avatar
From the rockauto site it appears that the top ball joints are labeled for either the forged or stamped version of the arm.
Old Aug 28, 2019 | 09:33 AM
Zrock's Avatar
Super Quad Patrol
Forged are thicker they are more the tubular design much heavier
https://www.readylift.com/blog/2017/...-control-arms/
Old Aug 29, 2019 | 04:17 PM
Yeah I see now mine are def stamped.
Considering the mileage I've decided to change out everything I can. Ordering 2 new top A-arm assemblies, 2 lower ball joints, 4 lower A-arm bushings, 2 new strut assemblies w/ springs, and 2 sway bar links. This only leaves the tie rod ends which there is a chance are not original. This car was part of a fleet that got regular maintenance so since I didn't see any movement at the outer tie rod ends when I was doing the 3 & 9 push test I'm thinking they may have already been replaced. I'll put in everything I've ordered and see how the steering is after that. Do you always do both inner and outer tie rod ends at the same time or is it common just to do the outer, or just the inner?
Found a decent set of ebay shock and spring, strut? assemblies for $150 but it's specified as fitting the interceptor model whereas mine is just the base model. Would they still work ok?
Old Aug 30, 2019 | 09:18 AM
Zrock's Avatar
Super Quad Patrol
Since your going to have to pay for a alignment i would replace the inner and outer tie rods as well.. Then its all done and should not have to worry about it for years to come.. I think the interceptor model was the police version so it would have had a stiffer suspension to help with performance. Should fit but im not 100% sure
Old Sep 13, 2019 | 08:09 PM
  #15
Found a fairly comprehensive front end kit for a great deal...like $137 for all of this...
2006-11 Ford Lincoln Mercury Steering & Suspension Kit 12 Piece Set - 1ASFK05040
https://www.1aauto.com/2006-11-ford-...t/i/1asfk05040
I'd rather go with something more dependable like Moog at least on the lower ball joints.
What do you think? Should I go with this kit and save? She's got 320k on her now.
Old Sep 14, 2019 | 09:26 AM
  #16
Zrock's Avatar
Super Quad Patrol
Personally i would go with the OEM from rock auto or a good name brand... You get what yu pay for
01RedRubicon
Aug 8, 2005 05:10 PM
Cammer
Apr 13, 2004 08:38 PM
GregV
Apr 10, 2002 01:59 AM
sxr6
Jun 12, 2000 10:12 PM
