Replacement Battery - ATV
Old Oct 16, 2019 | 09:07 PM
2005Buck's Avatar
Default Replacement Battery - ATV
Getting tired of purchasing a new battery every year for 2005 Buck 650 (electric start only - no kick).
Recommendation on replacement battery vendor / type that may last a few years?
In Wisconsin - ATV sits in garage during winter months. I can / do charge them as needed.
Open to suggestions!
Old Oct 17, 2019 | 09:55 AM
Kymco 450i's Avatar
Go with a sealed AGM battery then keep a battery tender hooked up when your not using. I have leads connected to the battery with a plug, when I put my machine in the barn I just plug in the battery tender and go about my business. A simple pull the plug and go next time. My battery will be 4 yrs old in Jan.
Old Oct 17, 2019 | 11:45 AM
Alex G.'s Avatar
MotoBatt, their sold on Amazon.
I always try to select a more powerful one than the stocker.
Old Oct 19, 2019 | 08:31 AM
Zrock's Avatar
Super Quad Patrol
I have had the best luck with walmart brand battery. My battery tender just has the cigarette lighter adapter on it so i just plug it in when done and walk away.
Old Oct 19, 2019 | 11:10 AM
Kymco 450i's Avatar
I think the key to longer battery life is to keep them charged. If a battery drops below 12v it probably will never fully recharge. Most battery mfgrs recomend to never drop below 12.4 volts unless you have a deep cycle type battery. The battery tender keeps batteries in the proper range thus giving them linger life, especially for those not used often.
Old Oct 20, 2019 | 10:07 AM
Zrock's Avatar
Super Quad Patrol
Not sure about other machines but i find cat cannot keep a battery fully charged especially if you use the winch.. First 2 years i replaced the battery every 6 months with a over priced dealer battery. Then i switched over to a Walmart battery and never had a issue for over a year.. I started to slow down on riding and put tenders on all the machines... I run 2 cats and a import and swapped all the batteries. I also find our local walmart is lazy and never change shelf tags so i usually get em for $20 cheaper
Old Oct 20, 2019 | 10:21 AM
Kymco 450i's Avatar
My last AGM sealed battery was an 18 ah and was only 44 shipped to my front door. Battery is 4yrs old and still going strong. Stays on a battery tender unless being used.
Old Oct 20, 2019 | 10:31 AM
greg74's Avatar
Even if you don't ride in the winter, I find that just simply starting the machine and letting it run a few minutes a couple times a month is better than simply putting the battery on a charger hoping it doesn't go dead. Just start it up, let it warm up and idle for a few minutes with the garage door open and then shut it off. It keeps the gas from getting stale as well.
Old Oct 20, 2019 | 11:03 AM
Kymco 450i's Avatar
Much better for the engine to run a couple times a month, keeps a good oil coating on everything! You will still find a battery tender will add life to the battery if there is a long period of time between runs. I have nuumerous toys with batteries and they all are on tenders when sitting for more than a week or two.
Old Oct 22, 2019 | 07:43 AM
Alex G.'s Avatar
A bit off topic but, Ya gotto make sure that the machine fully warms up when your starting it a few times a month to charge the battery and lube the internals. I run mine until I hear the rad fan come on. It eliminates the carbon build up on the plug....
