95 kawasaki bayou 220 not wanting to start
Old May 11, 2021 | 07:54 PM
jgarc12's Avatar
Default 95 kawasaki bayou 220 not wanting to start
I recently got a 95 bayou 220 got a new battery put in, the starter button does not do anything, the solenoid and starter are good when I jump the solenoid but still doesn't start just turns over. I am wondering if the starter relay is bad would that cause no spark and the push start not to work any help would be really helpful. I also have a total of four wires that are not connected they are a brown and white wire that both have power to them and a blue and black w/ yellow that do not have power the brown and blue one come from the same area and same with the white and black one these wires are located in the middle of the body of the atv any help would be great.
Old Nov 22, 2021 | 12:04 PM
nny's Avatar
nny
I dont know if you've found a solution yet but check your pulse coil with a multimeter check for continuity if the circuit is broken you wont get a tone if its good youll get your tone. this part signals the coil to spark.
Old Nov 22, 2021 | 12:06 PM
nny's Avatar
nny
also the black and yellow wire is your ground see if it has continuity if not you need to ground it
kawasakijet52
May 15, 2014 10:26 PM
TheWastedYears
Sep 10, 2010 09:54 PM
rberry3123
Mar 31, 2008 06:11 PM
RRyder01
May 7, 2005 01:49 PM
EDISTORIVERRAT
Jul 16, 2003 12:39 AM
