Please help with Mule heater.
Old Feb 9, 2005 | 10:27 PM
EAB's Avatar
EAB
Default Please help with Mule heater.
I have a buddy that just installed a factory heater in a mule but it wont work. He's had it to the dealer and they cant figure it out either. They say its installed correctly, raised the front 16 inches off the ground to fill it, pulled the water pump to make sure the impeller is still good but still no heat. Any experience or ideas? Thanks
Old Feb 10, 2005 | 12:17 AM
400PrarieXLT's Avatar
We have a fleet of these things at work and they all have the factory heater. There are a few of them that refuse to work and I think its becasue they are cooling too well to make heat. Maybe a thermostat or something? If you block the coolant flow to the radiator by pinching a hose , it will have no choice but to disapate heat through the heater core, might be worth an expirement.
Old Sep 20, 2012 | 09:43 AM
johnesc's Avatar
Default Mule cab heater
Hi, new to the site and new to me 2005 Diesel Mule 3010. I have a Curtis Cab on the mule and want to install a heater that uses the engine coolant and a heater core type heater, can some one send some pics of where to put the heater in the cab, and pics of coolant line hook-up? I have the factory manual but it doesn't cover where to hook it up.
TIA
merryman
Jan 19, 2016 04:29 AM
ManuelCarrillo3
Where to Ride
Jul 27, 2015 07:53 PM
Aitch
Jul 21, 2015 09:40 PM
Larry S
Jul 4, 2015 12:54 PM
04LERaptor
Apr 7, 2004 10:37 PM
