Problem with 06 Ranger
Old Sep 1, 2005 | 11:54 AM
GretnaRyder's Avatar
Default Problem with 06 Ranger
Any help would be greatly appreciated.
Last Friday I picked up my 06 Ranger 500 Carb. After .6 hours it wouldn't start. There was a banging sound from under the seat. I lifted the seat and after investigating it was the fuel pump surging (trying to prime) so hard it was shaking the wall it is bolted to and creating the banging. I called the dealer they said "yep, some of the Rangers got a bad fuel pump" I took it off (no gas at all inside or in fuel line) drove to dealer (30 miles) picked up the new one, installed it and bing Ranger started right up. After one more hour the Ranger dies on my wife with the kids while I was at work. I get home, starts right up, I drive it around for about 15 minutes and yep, here is the banging and Ranger dies. Fuel pump is surging again. I leave it and call the dealer the next day. The don't know but they appear to care. Hauling the machine in is a PITA so they agree to switch out the fuel pump one more time. After sitting for 24 hours the Ranger starts right up and when I take the fuel pump off it is full of gas, I also checked the inline fuel filter and it is good. Anyone have any ideas why this is happening? Thanks in advance!
Old Sep 6, 2005 | 10:48 AM
Bionic's Avatar
Its "happening" because it says"polaris" on the product. JK. Sounds like you may have a vac. prob with your tank. Does it release air when you take the cap off?
Old Sep 6, 2005 | 11:14 AM
That is the first thing I thought of. I removed the gas cap and it still wouldn't start. After installing the third fuel pump it has been running but when it is good and warmed up I can hear the fuel pumping knocking under the seat. Yes, I am sure it is the fuel pump. I'll keep everyone updated. Any other ideas are welcome!
Thanks
Old Sep 6, 2005 | 01:46 PM
TPR's Avatar
TPR
The Champ
Does the fuel line run anywhere near the exhaust or any other source of high heat. I know nothing of the rangers, but it sounds alot like what happened on an old motorhome I had. Vapor Lock. The fuel being vaporized before getting to the pump, and since it works until the engine heats up there maybe somthing similar going on.
TPR
Old Sep 8, 2005 | 04:35 PM
colt2245p's Avatar
i hate to tell u but we are having issues with the fuel pumps on the units we have in stock we have had about six of them with bad pumps polaris is aware of the problem and have changed part numbers and are sending out new pumps it sounds like you are hitting the shield with a wrench and to u bionic get over your problems get on with life try another brand do something else but trash
Old Sep 8, 2005 | 06:10 PM
[img]i/expressions/face-icon-small-smile.gif[/img]
That is exactly what it sounds like. That is also what my dealer said. I guess I have had some bad luck with the pumps. Hopefully they get the correct ones asap.
The fuel does not have time to vaporize from the tank to the pump. It's only about 12". Exhaust is far away. Good idea though.
Just a bad fuel Pump. Two of them for now.
Thanks for the info!
Old Sep 9, 2005 | 05:19 PM
TPR's Avatar
TPR
The Champ
Best of luck, I hope you get it worked out.
TPR
Old Dec 15, 2005 | 11:58 AM
Well after months the issue is solved. Polaris issued me two BAD fuel pumps to the one orginally installed. I blame the dealer for not catching it. On the Fourth attempt - bingo.
No more problems. I guess it's now a recall item - a BUNCH were shipped out and a LOT of people are pissed. Including me - I have better things to do.
I am impressed with the machine. Haven't been able to stop it yet.
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
southbayman
Jul 24, 2015 09:30 AM
J-Mack
Jul 4, 2015 04:19 PM
