Shifter problems POP-OUTS
Old Dec 21, 2009 | 09:04 AM
Les250cc's Avatar
Default Shifter problems POP-OUTS
I recently researched shifter problems. The results were that no matter what type of vehicle you may own in terms of UTV's there appears to be problems shifting from neutral to low or high or reverse. Sometimes it is only the indicator lights that don't work and at other times it is difficult to enter a gear or that you get the pop-out issue. The pop-out issue seems to be the most frustrating. Pop-outs in L (low) in 4X4 mode under heavy low appear to be most prelevent, there were lots of pop-out in high gear especially going up inclines of different degrees. I have spent some time adjusting mine, trying to balance between getting the L,H,P,N,R to sit so they don't pop-out under heavy load (in my case plowing snow) and having the indicator lights on. I would suggest we could all benefit if we combine our experience here and get some feedback with pictures on how to battle this problem and maybe even get some feedback to manufacturers on how to improve this shifting issue.
Attached Thumbnails Shifter problems POP-OUTS-cimg0156-small-.jpg   Shifter problems POP-OUTS-cimg0157-small-.jpg   Shifter problems POP-OUTS-cimg0158-small-.jpg   Shifter problems POP-OUTS-cimg0159-small-.jpg   Shifter problems POP-OUTS-cimg0160-small-.jpg
Old Oct 11, 2010 | 06:40 AM
iceman52's Avatar
Default pop outs
i too experience popping out of gear with a super mach 500, mine pops out if you release the throttle going down a hill, it will freewheel till you slow down and then slams back into gear with a loud thump,..anyone have a cure for this ?????
Old Oct 13, 2010 | 08:50 PM
4getful2's Avatar
mine was doing the same thing and sometimes you had to play with the shifter to get the nuetral light to come on .
check the connector pipe to make sure it's not bent(straighten if necessary)and then adjust untill you hear it sfiting in all the gears ,adjustment must start in neutral and need not be running. all it took, after i figured out which way to turn the connector,was a half turn
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Schneider
Jul 24, 2015 05:05 PM
hondarider1234
Jul 21, 2015 11:53 PM
