Help With Forum Software! A Place to get Help with the Forum.
90 falcon needs help
Old Jul 25, 2012 | 02:53 PM
OZZ123's Avatar
Default 90 falcon needs help
I welded the front end and didn't disconnect the + cable from the battery.So I changed the 10 amp glass fuse.Too a 20 amp new plastic type because it was getting the wires hot and blowing fuses.now it still is making the wires very hot when i turn it over.I did clean brushes in starter and it looked ok no burn areas ect,and it still got hot blow a fuse PLEASE HELP
Old Jul 25, 2012 | 02:59 PM
Jaster94's Avatar
repost this thread in the chinese section or the kids atv section. it'll get more attention faster over there. BUT, in the meantime, you should only have a 7 amp fuse between the battery and the solenoid/starter. it's blowing fuses for a reason and we'll get to the bottom of it shortly. you just don't need to burn the quad down in the interim and have a total meltdown of the wiring harness or burn up the starter.
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
ErikTheRed
Mar 8, 2006 03:21 PM
TrueGritScott
Mar 7, 2006 02:35 PM
hadaveha
Feb 4, 2006 03:18 AM
