400EX Handlebar Torque Spec
I did noy know that we used a torque on the bars. Just lock tight the front bolts as tight as you can get them. Then tighten the back ones up. I am sure there is a spec but, maybe only one or two people use it. They are 10mm bolts and most 10's get about 30 ft/lps.
many 250r's
87 250x
99 400ex
many 250r's
87 250x
99 400ex
The only torque specs the factory manual gives are for the two clamp bolts that attatch to steering stem-29 lbf.ft.As for the bar clamp bolts tighten front bolts tight first then rears.I would guess appx 20lbf.ft should be suffecient.
WHOA! LET GO OF THAT BREAKER BAR & SOCKET! hopefully you haven't done anything drastic yet.
Renthal recommends 17, that's seventeen, ft lbs of torque on their bars. Set torque wrench at 1/2 the torque and after tightening to that reset to 17 and re-torque. Torqueing over specs can weaken and damage the bars, being alloy.
