rincon hesitation
Old Jun 23, 2003 | 02:07 PM
lindzey's Avatar
Default rincon hesitation
I just bought rincon and I have 112 miles in it and after riding some mile there is a hesitation during taking off from a stop. It takes
some throttle to make it start moving, more than needed when it does take off it learches forwarded like it suddenly engages a clutch.
Any help or ideas would be appreciated[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jun 24, 2003 | 12:43 PM
kford's Avatar
i would start with checking the fluids and the air filter. if all those are good, i would take it to the dealer and have them check the idle. i have two rincons, one has no problem from the stop and has 1400 miles on it. the other has about 250 miles and sometimes exhibits what you are describing but it is my wifes ride so i never knew. seemed to be better after the first oil change but i still feel it doing a stiff engagement once its throttled up from a stop. makes it hard for rock crawling. guess i gotta get off my rear and take it in as well.
good luck and post back what you find out.
Old Jun 24, 2003 | 12:54 PM
lindzey's Avatar
I called the dealer today and described the problem. They are calling Honda to get some info. I changed the oil and check cable adj.
This transmission on the Rincon works partly with a ECU module that controls the shifting but I dont know if that has anything to do
with this problem. I will let you know the results.
Nondem
Feb 22, 2020 12:20 PM
hueby
Nov 6, 2015 11:34 AM
house1
Aug 9, 2015 10:49 PM
Austins
1) Engine problems..
Aug 9, 2015 02:28 AM
D-Hagz
Jul 4, 2015 02:19 AM
