dyno jets vs. stock jets
Old 06-24-2003, 01:24 PM
SR71A's Avatar
Default dyno jets vs. stock jets
Back to the "plug chop". It is possible to do this on a semi-auto quad. Do your run as you would on any other bike, but when ready to chop simply lift the shifter as if your going to the next higher gear (which you don't have) but don't let off the shifter until you have stopped. You have a clutch (actually two) it's just operated by the shifter instead of a handlebar clutch cable.
Old 06-24-2003, 01:50 PM
03foreman's Avatar
That should work for the Recon but my Foreman is and ES (eletric shift) if you hold the upshift button it still completes the shift
ReconBayou
10-31-2022 05:37 PM
Pehter
09-04-2016 08:22 PM
XxS0ccerstarxX
09-24-2015 02:02 PM
Todd C Wadas
2) Chassis problems..
09-23-2015 11:31 PM
XxS0ccerstarxX
09-22-2015 02:40 PM
Quick Reply: dyno jets vs. stock jets
