TRX 450 Foreman frame Geometry
Old Aug 7, 2003 | 01:55 PM
Huntmastr1's Avatar
Default TRX 450 Foreman frame Geometry
My Foreman has been wrecked. The left front wheel is leaning in. I cannot find the bent component. All measurements comparing to the right side seem to be correct. A bent frame or A arm would only have to be 1/8" off to cause the wheel to lean as it is. Is there a source for frame measurements.
This would save the cost of alot of parts changing as the dealer suggested.
Thanks,
Jeff
Old Sep 7, 2003 | 09:03 PM
WeAREsane's Avatar
Is your rim warped?
Old Sep 7, 2003 | 11:13 PM
jmrpage's Avatar
hello
take a very good look at the upper and lower ball joints and the spindle . also measure the control arms from the mounting point on the frame to the bottom of the balljoint fixed end and compare them side to side . look for cracked paint on the frame , control arms and spindle .. hope this helps
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
EIF
Apr 20, 2017 07:15 PM
mark23
Oct 1, 2015 09:57 AM
patrick.oc123
Sep 15, 2015 02:45 PM
