Slow return to idle
Old Aug 15, 2003 | 08:48 AM
lesnes's Avatar
Default Slow return to idle
i have an 88 honda trx300, and the only problem i have with it is it has a slow return to idle. After you rev it or rolling along and have to change gears the rpm won't slow down enough. I can't seem to adjust it enough to fix it.
Old Aug 15, 2003 | 09:36 AM
garyc660R's Avatar
I would first check for a air leak. I have seen bad port jobs do this and a clogged up carb as well.
Old Aug 15, 2003 | 10:04 AM
TKBOB2000's Avatar
Yep that sounds like an air leak for sure. If it was a 2 stroke I would say crank seals, but since its a four stroke I cant say for sure. But I would suggest checking the rubber in-take boots they might be cracked and sucking in air.
Old Aug 15, 2003 | 10:37 AM
lesnes's Avatar
I checked the rubber boot and its fine. Its still in good shape.
Old Aug 15, 2003 | 11:35 AM
KGB's Avatar
KGB
Try spraying some carb cleaner or starting fluid aroung the intake while its running, if it revs up when you spay a certain area, inspect there for air leaks.
Old Aug 15, 2003 | 11:37 AM
trx250Rob's Avatar
This is also a sign that your pilot jet is too lean.
Old Aug 15, 2003 | 11:50 AM
TKBOB2000's Avatar
Great Idea... forgot about that little trick...be careful with the quick start (starting fluid) its pretty strong stuff and can do some damage if hte motor gets a good whif.
2quiker
Mar 22, 2022 08:36 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Minimod
Sep 10, 2015 08:03 AM
black_thunder
Sep 6, 2015 04:41 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
