300ex is having some problems now
Old Aug 26, 2003 | 02:53 PM
manual's Avatar
Default 300ex is having some problems now
Hey i got a 300ex used and it was working fine, now its having problems(it will start and run and all), but when i give it gas sometimes it will backfire, and when i start it up it smells like oil is burning a little and it comes up through my fenders(would that be caused from the piston ring possibly)? My timing belt is also lose, and its adjuster is broke, just gotta find a place that sells them anyone know of any?
Old Aug 26, 2003 | 03:02 PM
sickmojave's Avatar
I think I would get that fixed and see what happens.(BTW it's a chain not a belt) and you could try servicehonda for the parts you need.
Old Aug 26, 2003 | 03:10 PM
manual's Avatar
hmmm u know where it would say item numbers at...(don't have manual currently)
Old Aug 26, 2003 | 08:33 PM
manual's Avatar
up
Old Aug 27, 2003 | 05:49 AM
RideRed81's Avatar
Replace the timing chain tensioner, it the chain is still too loose then replace the chain and time it correctly, problem should be solved.
Old Aug 27, 2003 | 09:32 AM
Honduki's Avatar
Chain sounds loose and that means it is out of time. If it is out of time it will run like poo!
Old Aug 27, 2003 | 05:13 PM
Semms40oz's Avatar
You say "it" comes up through your fenders. Do you mean smoke? If so you have a oil leak that is dripping on the head pipe, fix that!
Replace the tensioner and cam chain to be on the safe side. Then adjust the valves.
A loose cam chain will cause major damage when your timing jumps. then when your valve smashes the piston just hope the cylinder can be saved
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
