footpeg extensions, ne thing i should know?
i'm gonna get some of those extensions for the footpegs for my 400EX. they r the type that r turned up on the end and have a little tab to make sure that your foot doesn't slip off. has ne body had ne problems with these? they seem like there shouldn't be ne problems. but i wanted to check ne way.
Be sure to re-jet your carb after the footpeg add on..........U'll be running leaner depending on the angle or "lean" of the foot peg extension........<grins>
U'll really like them, much more positive foot engagement.......
Glad to help u out N E time mannnnn.
I run foot peg "Wings" on all my quads........it takes a bit of getting used to for mounting and getting off the quad, but you get used to it.......for hard cornering the wings really do help keep you boot on the foot peg.
James Lucky has cheap cheap footpeg extension for only like $12-15 bucks a set that are stamped steel or heavy tin........Rath Racing has some wicked sharp stainless steel ones that are about $90, and the ultimate are Doug Roll $225 double wide units........
I run the cheap ones, and they really work out great.
toonces
Oct 16, 2019 12:11 PM
