problems with my honda
Old Nov 10, 2003 | 07:38 PM
MartyLey's Avatar
Default problems with my honda
When having problems with clogged up carbs/jets, like when you let it sit a while with no fuel stabilizer, I've had good luck using a product called Sea Foam. It comes in a white can. I use it in all of my vehicles. It works great for cleaning clogged carbs and keeping them clean. I use it about once every three months or so. But, for a severly clogged carb/jet here is what I've done and it worked. First drain the fuel. Then put in fresh fuel. Mix about 3 ounces per 5 gallons of gas. Start the motor and let it run. Run it untill it gets warmed up. Then turn it off and let it set over night. The next day run it until it runs out of fuel. Then do it over again. I've had very good results doing this.
I hope it is helpfull.
Old Nov 10, 2003 | 07:52 PM
honda450es4x4's Avatar
i have the perfect fix
sell the thing and let someone else worrbout ur problems and buy a new one honda that is
Old Nov 12, 2003 | 06:09 PM
iliveintn's Avatar
i figured it out. its a problem somewhere in the carburetor whenever it starts doing it i just push the throttle as far as i can push it a few times and it usually fixes whatever is wrong in the carb
Sjrpp
May 2, 2023 03:59 PM
hugemoth
Jul 20, 2020 03:28 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
