400EX - loss of power
Old Jul 3, 2000 | 11:45 PM
toyman's Avatar
Stock 400 except for K&N filter, pilot jet to #40.
First gear is great, pulls the front end right up. Second gear falls on it's face - no power, even when droppin the clutch... any ideas? I checked the plug burn and it's perfect????
Old Jul 4, 2000 | 02:57 AM
Motorhead's Avatar
Maybe try like a 155 main jet?
Old Jul 4, 2000 | 11:21 AM
400exalltheway's Avatar
clean you filter and fuel line. they may be clogged
Old Jul 4, 2000 | 11:11 PM
Lucis's Avatar
check the boot that goes into the carb. Mine keeps poping off causeing my mid to high end to bog down...It comes off every time I ride.
Old Jul 5, 2000 | 01:36 AM
azrob's Avatar
Turn the petcock to off and remove the 17mm cap from the bottom of the carb, then unscrew the main jet. It should be around #148 as I recall. Sounds like your main jet is too lean (need at least the #148).
Old Jul 5, 2000 | 11:28 PM
toyman's Avatar
Main jet is OK, plug looks good.. I drained the gas tank and dumped high octane in, made quite a bit difference. Pulls hard in first ok in second and can start in third without stallin.
Old Jul 6, 2000 | 01:57 AM
luckywilson's Avatar
check your vacume needle slide in the carb. They have been knowen to stick. If you have a K&N filter get rid of it.They do not work very good. Put your hand inside the intake boot and you will fill the grit that stickes the sides.
2quiker
Mar 22, 2022 08:36 PM
mtdewmn
Jan 19, 2017 12:13 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
toonces
Sep 5, 2015 01:14 PM
Pahuntman
Sep 5, 2015 11:07 AM
