250R Carb Problem
Old Feb 20, 2004 | 02:24 PM
BrocksZ's Avatar
Default 250R Carb Problem
Currently, I have a 39MM on it, but the bolt on the bottom of the carb stripped out. Not the nut part that holds the bottom piece on but the actual piece that it screws on to. Anyway I was thinking about just buying a whole new carb. The mechanic said get rid of that piece of junk 39MM carb I have on there. So..., what size should I get?
Old Feb 20, 2004 | 05:32 PM
briansgi's Avatar
First, what size cylinder are you running? If you are still stock, the original carb was a 34MM. I would certainly not run a 39 on a stock cylinder. I've ran the 38MM Keihin Airstryker carb on 2 different 310 kits and it's a great carb for a big bore. It would be OK for a stock cylinder but you will loose some bottom end punch. For a stock cylinder a good setup would be a 36mm and with a big bore setup I'd go with a 38mm.
Old Feb 20, 2004 | 06:14 PM
dragracer789's Avatar
I think your talking about the drain screw (bowl screw) Your talking about the screw on the very bottom of it and when you take it off you can see the main jet right there right? If the screw is striped Im sure you can get another one. If the threads where it screws into is striped I wouldnt bother and get a new carb.
Old Feb 20, 2004 | 08:44 PM
BrocksZ's Avatar
Yeah its the main drain swrew. What ever it is that that screw/bolt screws on to is stripped. Is that the main jet? I was thinking about going with the 36mm. I'm pretty sure its the stock bore.
Old Feb 20, 2004 | 11:04 PM
No that screw is not the main jet, but when you take it off that little gold thing with the hole in the middle is. Yes the 36mm would benifit you with a stock cylinder. 39mm is overkill.
Old Feb 21, 2004 | 10:27 AM
BrocksZ's Avatar
Cool, thanks. Think I'm just gonna buy a new one.
Old Feb 21, 2004 | 10:48 AM
Nicname's Avatar
Don't buy a new carb, just see if you can buy the new bowl for the bottom of it. I would check with ESR, if they don't have it try going through Keihin/Sudco. Yes for a stock 250 the 39 is overbore, but not overly so. I use a 38 A/S on a small bore engine and like it. There are many people out there that use 40.5 Keihin's on factory cylinder bikes. If you switch back to a smaller carb, you'll have to buy more than just a carb. You may have to buy a cable, intake, airbox boot, and all the other little headaches that come with it. Bottom line: The 39 Keihin is a good carb, it just needs to have more motor behind it.
Nic
Ty Speece
Jul 2, 2015 04:59 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
