Works front shocks for 300EX with 400EX a-arms
Old 07-12-2000 | 09:14 PM
94DGblaster's Avatar
I was talking to sandy at works shocks and this is what i was told.
The normal 400EX shock is 16.25" long. They can make a special shock that is 14.5" long that will fit in the stock brackets.
Will i gain in suspension travel?
My main reason to do this is i want a wider front end and i can get a complete set of 400EX A-arms for around 200. That's a lot cheaper than aftermarket! And the top right A-arm is bent and the bottom left is bent. So i figure i need a new set anyways
Old 07-12-2000 | 10:48 PM
hondatrx300ex's Avatar
whats the price of the special shock? so this shock is made to put 400ex on a 300ex frame? dual or triple rate? anyways see ya
Old 07-12-2000 | 10:52 PM
I haven't got a price yet.
Old 07-13-2000 | 01:20 AM
THEXOTIC1's Avatar
Look into the shock tower setup the relocates the top mounts on the 250x/300ex to a 250R setup. You can also use stock 250r a arms, tie rods, and u will need longer brake lines. The tower bracket is $135 then u need a welder to cut and weld this on your 300ex. Email if u have any questions. I have this setup on my TC405ex see the link for photos
Old 07-13-2000 | 08:18 AM
skull's Avatar
hey where can I get the kit to do the conversion to 250r suspension. yea the suspension on my 300ex is takin a beatin, I need to upgrade bad. also I seen another guy on this post who had 400ex a-arms on his 300ex and they bolted right up, and the stock brake lines were long enough.
Old 07-13-2000 | 10:13 AM
veedell has a bolt on set up. If he ever e-mails me back with some templates or something, I was going to do this.
Old 07-13-2000 | 10:44 AM
THEXOTIC1's Avatar
Atv racing has the tower weld on kit for $139.95 Their phone number is 602-516-8640 or web site is
www.inficad.com/~atv
or their email is atv@inficad.com
Old 07-13-2000 | 12:58 PM
i refuse to weld on my frame..i just can't do it..!
Old 07-13-2000 | 01:09 PM
Skunky's Avatar
y can't you use your stock shocks?? I finished last night ripping off my stock a-arms, axle, and swingarm. Tonight i will be putting on my +2 a-arms I will still be using my stock shock. What this is going to do is raise my quad about an 1/2 due to the longer travel of suspension.... my durablue eliminator axle and rpm swing arm should be here monday
Old 07-13-2000 | 02:03 PM
i've heard they won't mount up and besides my front shocks are dead. So i'm not worried about it.
do you want to sell your stock 400EX a-arms? If so e-mail me.. aaron@1st.net
Quick Reply: Works front shocks for 300EX with 400EX a-arms
