250R throttle help??
Old Mar 19, 2004 | 08:13 PM
TrxR's Avatar
Default 250R throttle help??
DaBeechMan : If the cable is too slack will it let the slide too far down and cut off the fuel?? Or how does a bad cable or slide spring affect the idle??
THANKS
Old Mar 19, 2004 | 08:18 PM
DaBeechMan's Avatar
no, if a cable is a little too long you adjust it with the carb top and the adjustment on the throttle housing. If its too "short" it may not be short at all, just hanging up in the cable housing causing it not to slide freely. If its a spring they do wear out sometimes and that could be a problem as well
If in your case its idling too high the sticky cable can cause the slide to be open a little more then it should. Granted i cant hear just how high its idling but its just a theory. If the spring is bad it just wont have enough strength to close the slide
Old Mar 19, 2004 | 08:42 PM
TrxR's Avatar
my problem isnt that it idling too high its that it wont idle at all[img]i/expressions/face-icon-small-sad.gif[/img] It just dies when you let off the throttle otherwise it works great. Is it possible for a stretched cable to let the needle and slide down too far??
Old Mar 19, 2004 | 08:44 PM
DaBeechMan's Avatar
my bad. Make sure there arent any kinks in your cable then adjust your settings
Old Mar 19, 2004 | 10:50 PM
  #15
bansheeesmoker's Avatar
Have you messed with the idle screw (twisting the choke switch up and down)? Dumb question but have to ask.
Old Mar 20, 2004 | 07:39 PM
  #16
TrxR's Avatar
maybe I go this backwards but my manual says the choke is the air screw and the screw on the body is the idle screw?? anyways I got the choke one at 1 & 7/8's turns out. I am also wondering if it might be my needle? Also how does the needle affect it being rivh or lean or does it??
Old Mar 20, 2004 | 07:47 PM
  #17
RoughRider01's Avatar
Im guessing its just your idle is set to low, the needle doesnt really affect how its idling.
Old Mar 20, 2004 | 07:53 PM
  #18
TrxR's Avatar
If ive been playing with the right screw the idle screw doesnt do a thing [img]i/expressions/face-icon-small-sad.gif[/img]
hueby
Nov 6, 2015 11:34 AM
Alex Rodak
Sep 13, 2015 12:30 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
