OIL LEAKING FROM CYLINDER!!
Old Jul 17, 2000 | 04:05 PM
power7's Avatar
I need a little help, what do you think it is and how easy will it be to fix?
Matt
95 300EX
Old Jul 17, 2000 | 05:28 PM
Raychalp's Avatar
It is most likely a gasket. You should get it changed right away to prevent running lean and seizing the engine.
Old Jul 17, 2000 | 08:33 PM
THEXOTIC1's Avatar
from the top of the cylinder or the bottom where the cylinder meets the bottom end??
Old Jul 17, 2000 | 08:34 PM
THEXOTIC1's Avatar
You might want to take the front plasics off and remove the gas tank. Then retourque all the top head bolts. they will loosen up eventually.
Old Jul 17, 2000 | 11:03 PM
power7's Avatar
It is from the top, I think I'll retorgue everything, hopefully that will fix it. Thanks for the help
Old Jul 17, 2000 | 11:08 PM
gregsims's Avatar
I agree with thexotic1. Just be very careful not to over tighten and break a head bolt. I did that about 12 years ago and learned an expensive lesson. Polaris's are know for this and this solution usually works.
Greg
exmotocrosser
Sep 13, 2019 06:12 AM
Dewhound
Apr 20, 2017 02:25 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
