PEP easy clutch lever for 300ex
Hondatrx300ex...
You said you would do this but you didn't want to loose your Reverse. Why would you loose that !! Isn't the easypull clutch lever just mounted differently so there is more leverage to pull on, this makes it a easier pulling motion. I don't believe you loose reverse..
Correct me if I am wrong. I do not have this part..
Jason
Jason
well I don't think the pep lever will fit the 300ex perch. the pep easypull comes with the perch.therefore if you take your perch and put on the pep you will lose the little red button you use to put it in reverse.I may be wrong but I haven't seen a pep lever that will fit the stock perch. later
gogogo
10-15-2015 05:40 PM
tank10rnk
08-10-2015 08:19 PM
