Periodic Maintenance on a 400EX
Old Jul 25, 2000 | 12:44 AM
MadDogg's Avatar
It appears to me all the suspension parts are sealed... no fittings to grease. Are there any parts on the 400EX that should be taken apart and periodically lubed? I feel like I'm overlooking something just doing the filters, oil, and chain lube. For example, how often should the swingarm bushings be lubed?
Old Jul 25, 2000 | 01:39 AM
azrob's Avatar
The old TRX250r was the same set up and their still hanging in there. Don't fix something until it breaks.
Old Jul 25, 2000 | 11:32 AM
coryatver's Avatar
Check the tire pressure every once in a while. not that i do that. Just something else to do.
00 400ex
http://www.geocities.com/cory_14/
Old Jul 25, 2000 | 12:45 PM
Mike Frey's Avatar
I think it's a good idea to get the valve clearance checked every year. Good insurance at $40.
Old Jul 25, 2000 | 11:49 PM
demp223's Avatar
If you ride in water alot then I would definitely break down the axle carrier and front spindles and regrease the bearings once a year.Same goes for swingarm,a-arms,and all suspension pivots.Dont forget the steering stem as well.If you primarily ride in the dry stuff then every other year would be fine.Lube cables every 6 mos to keep them working smooth.I check valve clearance every 100hrs personally.Overall check of all nuts and bolts every few rides just to make sure nothing has come loose or missing.Its nothing to invest time in preventative maintanence when you consider a whole riding trip could be shot if something breaks down due to neglect.
Old Jul 31, 2000 | 03:16 PM
bushdogz's Avatar
demp223 is right on the money. Get yourself a good manual and dont be afraid to work on your machine. The best investment you can make is a stand to put your bike on while you work on it. Then you get a mechanic chair so you can zip around.
Old Aug 1, 2000 | 07:20 AM
Mike300EX-99's Avatar
If I was you I'd check and regrease your a-arms, pivot bearings and shock mounts at least twice a year if not more. Axle carriers at least once a year. Honda doesn't use lots of quality grease when building them. I did my 300EX after a few months of riding and everything was in desperate need of grease. It's much cheaper to invest time than money.
Old Aug 1, 2000 | 10:33 AM
coryatver's Avatar
I have a 00 that i got in april..... I wish i new how to take all that stuff apart and grease it. And also how to check the valves.
00 400ex - ac mudscreen front bumper, nacs headlight covers
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
wrencher82
Sep 28, 2015 10:02 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
