Question For 300EX owners
Old May 5, 2004 | 11:13 AM
hondabigred's Avatar
Default Question For 300EX owners
Does the 300EX have engine braking. Like when you let off the gas going downhill does the motor start holding you back or do they just sort of free wheel and you have to use the brakes all the time.
Old May 5, 2004 | 11:28 AM
jumpman23's Avatar
All vehicles with a manually selectable transmission will allow the rider/driver to use 'compression' (engine) braking...
Each gear only allows for a specific top speed, which is dependant on engine & transmission configuration.
Old May 5, 2004 | 04:22 PM
hondarider300's Avatar
yea if u go 5th gear down a small hill u will free roll but if u put it in like 2nd then u will go slow down it
Old May 5, 2004 | 05:03 PM
I know if you use a lower gear you will go slower, I found a 300EX for cheap and I was thinking about getting it for an extra bike for freinds to ride. I have a Warrior now and I know when you let off the gas on that thing even in 6th gear the engine really starts to slow you down and you don't have to use the brakes as much. I really like it this way and wanted to know if the 300 was the same way before I wen't to look at it. I know I used to have a Mojave and the engine braking was no good.
Old May 5, 2004 | 05:06 PM
also keep in mind 2strokes dont have as much as an engine brake they will just rev extremly high but wont slow down as much as a 4stroke
Cole Hadden
Jun 15, 2025 09:05 AM
gogogo
Oct 15, 2015 05:40 PM
austinwhitton
Aug 11, 2015 06:21 PM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
