epoxy for oil leak???? please help fast!!!!
Old May 6, 2004 | 09:26 PM
250xRKrider's Avatar
Default epoxy for oil leak???? please help fast!!!!
i just cracked my engine case, and i'm wondering if i can use epoxy to fix the oil leak that it has... what kind of epoxy should i use, and wat temps should it be able to withstand?
Old May 6, 2004 | 09:39 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
You can use liquid weld. It will seal it up. Look for it at your local hardware store.
Old May 6, 2004 | 11:43 PM
2000IAWarrior's Avatar
JBWELD is suppose to work never tired it really.. tired it on a sled radiator.. but couldnt get it sealed because it was wet and didnt get the hold the 1st tiem
Old May 7, 2004 | 01:04 AM
Pirate Biker
Limping Rider!
JBWELD will work, used it on my son's KX125
Old May 7, 2004 | 04:33 PM
MrPlow's Avatar
J.B. Weld works great. Just make sure the area is clean and dry. Rough it up a bit mix it and be done with it. I like the "JB Weld quick" or whatever it is. Cures in 4 minutes total dry time 24 hours.
Old May 7, 2004 | 05:44 PM
sickmojave's Avatar
what part is cracked?
Old May 7, 2004 | 06:58 PM
i got some of that JB weld stuff, and i'll be putting it on asap, so i'll let you know if it fixes the problem.
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Oct 31, 2022 05:37 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
