carb problem
Old May 10, 2004 | 07:24 PM
BRAD14's Avatar
Default carb problem
Here lately me ex has been leakin gas out of the overflow tube pretty bad.I took it off and cleaned it up real goo with carb cleaner and that helped a little.Then i put in a new needle valve and that also helped but it still leaks.What should i do next?buy a new carb?I usually get about a week out of a tank of gas but now only about 2-3hrs.Isnt it craze this crap happens when im tryin to sell it?
Old May 11, 2004 | 09:46 PM
BRAD14's Avatar
anyone?
Old May 11, 2004 | 10:27 PM
havinnoj's Avatar
check your floats. also check that little pointed rectangular shaped thing that is attached to the float. If that isnt in there or in wrong then that can cause the problem you are having.
Old May 12, 2004 | 05:03 PM
dragracer789's Avatar
He said he already replaced it.... Anyway USUALLY the needle valve is what causes this problem to happen. Like havinnoj said check the floats and make sure it works properly.
Old May 12, 2004 | 05:13 PM
BRAD14's Avatar
the floats are in great shape and do no have any holes in the.I was told by a reliable freind that there was something you could bend up to adjust it.anyone know what hes talking about?I might just take it to him and let him fix it cause its pi$$ing me off.
Old May 12, 2004 | 05:19 PM
Flynbryan's Avatar
Hes not asking you to check the condition of them. Hes asking you to check the set float height for the floats. Which is what your "reliable friend" is telling you to do as well. If you have the floats set wrong(adjusted by bending the tab that is secured to the float valve) it will cause you to get overflow from the carb.
Ty Speece
Jul 2, 2015 04:59 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
