What does a pilot jet do?
Old Jun 23, 2004 | 04:36 PM
  #21
hondabuster's Avatar
Default What does a pilot jet do?
Will it idle with the choke on? If so the pilot jet is plugged.
Your mixture screw is number 14 in this picture
carb pic
Old Jun 23, 2004 | 05:07 PM
  #22
400exmagician's Avatar
how do i adjust the throttle cable?
would i be better off taking it up to a shop?
Old Jun 23, 2004 | 05:26 PM
  #23
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
yes,,,,you might be better off taking it to the shop this time
ask if you can watch
It sounds like your Pilot (slow)(42) is clogged,,,and not letting any fuel thru
The hole is tiny,,,and can get gummed up easy if the bike is stored outside for any period of time.
you can try removing and inspecting your Pilot Jet (42).....blow some air thru it and be sure it isnt clogged (hold it up to a light to see if you can see thru it fine).
Old Jun 23, 2004 | 05:28 PM
  #24
Bing's Avatar
Super Quad Patrol
Also check your boot that you mount your carb to. There must be a perfect seal from the boot to the head,,,and also the boot to the carb.
Any unmetered air that is leaking in will cause a drop in vacuum,,,and possibly not even suck the fuel thru the Pilot Jet.
Old Jun 23, 2004 | 05:37 PM
  #25
Thanks a lot guys, i'll give that stuff a try...
if it doesnt work i guess ill have to let someone else fix it for once, it kinda makes me sad lol.
I ordered the pilot and main jets and they should be here by friday, so by monday i will have the things installed and then ill get back to you all and tell you what was wrong, and what was done to fix it, if i figure anythign out by then ill post it
thanks again
QuadRiders
Oct 22, 2015 04:13 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
Aitch
Jul 21, 2015 09:40 PM
