MY 400EX BRAKE PEDAL IS STUCK!!!
i know it is the pedal because i unhooked the hydraulic system, and took out the carter pins and all.. I tried everything to get it out... wd40 and oil don't work, i can't get it inside of the housing... the pedal is extremely hard to move causing my brakes to stay locked once engaged. anyone have any suggestions??
BTW: i even ratchet straped it to my garage wall, and it did nothing!
Ok, well, I'm sure you already figured this out, but here's how the service manual says to remove the pedal:
1. Disconnect the push rod from the brake pedal by removing the cotter pin and joint pin.
2. Remove the return spring from the pedal (do you still have a return spring?).
3. Remove the cotter pin, washer, and the brake pedal.
Sounds simple, so I'm guessing you've already tried this, but the pedal doesn't want to come out of the chassis. I guess I'd try a hammer and punch to drive the pedal out (but don't get carried away, hehe). Try some penetrating oil too, not just WD-40, but maybe like JB-80, that stuff works awesome. Other than that, I dunno what to tell ya.
I have tried to hammer mine out numerous times, and it is just not working. I am trying to hammer from underneath. I have gotten the pedal to move back and forth with some force put on it, but coming out just does not seam to work. Do you have any suggestions, is there something I am doing wrong?
Thanks,
Nick
Thanks,
Nick
BTW - There is another product that is amazing for freeing stuck parts. It is called Kroil. My machinist at work uses it and swears by it. I have not used it. But I can tell you PB Blaster worked in this situation.
I had the same problem with my 400EX. It is a bitch to get out. PB blaster a prybar and alot of effort. I sanded the rod down real good and greased the crap out of it and put it back together. Marine grease or a good water resistant grease would be recommended.
Tank you for the heads up. PB Blaster worked along with a slim pry bar. Had to work at it but got it out. After discussions this with my millwright at work, we both decided the best grease would be resistant to water, dirt and have Teflon in it. It turned out I had such a product on the shelf at home. I used synthetic brake grease. Voila!
SixSpeed5
8
Aug 2, 2015 05:38 PM
