2001 Forman Rubicon, clutch I think??
Old Aug 13, 2004 | 11:03 PM
IceTray's Avatar
Default 2001 Forman Rubicon, clutch I think??
I know that Honda is got the best tranny but mine broke .Has anyone had this happen ?? When I put my mchine in gear it makes a grinding or a thunk thunk sound ..
I jacked it up and the wheels will spin and automatic tranny works in push button mode and automatic mode but when you put it back down it does the same.
When its in nutral it sounds like there is a little friction draging rpm down and a little grinding .. not like normal.
I pulled motor and pulled sub tranny cover andgears and everytning looks like new.
Then i pulled off the front clutch cover and the only thing I can see wrong is that on the clutch basket there is a burnt looking ring arround the basket about 1\2" all the way arround some aeras are burnt more than others...This is where Im at, waiting for special puller for clutch..
I hope this is it ...
Im pretty sure thats it but have never seen this before Please respond if you know anything about my problem.. Thanks Tracy..
01 Honda Forman Rubicon
85 kx 250 (for sale)
Old Aug 31, 2004 | 11:58 AM
bill2000's Avatar
I had a similar problem with my 01 rubicon and I had to have the tranny replaced. The dealer that I bought it from said that the 01 had a defect in the transmission and he has replaced 10 or 15 because of a bad bearing. When i took my clutch off i had the same burn marks on it and the dealer said it was from working the bike, like hauling heavy loads or dragging things. neither of the two problems were related.check the part # out on a new transmission, They changed it after 01 because of the problem with the bearing. I had about 5000 miles on mine when it went.
Old Sep 1, 2004 | 04:27 PM
marcopolo's Avatar
Bill2000,
How much did the repair cost??
Thanks,
Marco Polo
Old Sep 2, 2004 | 09:16 AM
bill2000's Avatar
I baught my quad in canada, I had to call honda canada my self but with alot of discussion I finally got them to cover the hole thing. They replaced tranny,oil pump,rings and all gaskets. I only had to pay for the oil and filter. The dealer I got it from was really helpful when dealing with honda. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 2, 2004 | 10:19 PM
Zingolly's Avatar
outch...when i bought mine the dealer said the hydro pump alone is $1300...I have a 03 model and so far no probs but after reading this it kinda makes me worry ...[img]i/expressions/face-icon-small-frown.gif[/img]
I hope honda completly resolved probs like this...
Old Sep 12, 2004 | 02:15 PM
IceTray's Avatar
Well I took my moter in to the honda dealer and he said that the best thing I could do is put it back togeather so he could do a few tests.
So I did and im still waiting for him to call me back .
Did you just call Honda custmer service or what??
Man, I hope that they will fix it .. or just pay for parts would be great!!
PLZ REPLY Tracy...
Old Sep 15, 2004 | 05:16 PM
bill2000's Avatar
The dealer called them and then th edealer gave me the number, I think it was customer service. I talked to the gent on the phone and told him what I thaught he should do. He called back the dealer and worked out the details. You need to have the dealer pulling for you or It probably won't work. GOOD LUCK!!
Old Sep 19, 2004 | 05:34 PM
IceTray's Avatar
Thanks for the info ill let you know how it goes..
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
chewy78
Sep 8, 2015 10:37 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
cdstang
Aug 31, 2015 07:52 AM
