Rincon Shifting Problem Going Into Reverse
Old Aug 25, 2004 | 04:26 PM
therock's Avatar
Default Rincon Shifting Problem Going Into Reverse
I hate borrowing other folks ATV's. I ran a friends Rincon a little while. I used Reverse once getting out of the shop. Did not run it hard at all. Upon returning it would grind when I attempted to put it into reverse. I had to go into forward and pull it really fast to get it into reverse.
What do you guys think?
Old Aug 25, 2004 | 06:59 PM
Duramax's Avatar
I'd start with cable adjustment.
Old Aug 25, 2004 | 07:58 PM
therock's Avatar
Can you give me some guidance on how to, and where the adjustment is and what I have to do to get to it?
Please?
Old Aug 25, 2004 | 10:26 PM
westpamudder's Avatar
I had that problem with mine except it would grind going into drive and reverse. It just came back from the first service when it happened, they had the idle set to high. Maybe that might be it, if you have access to a tach hook it up and check it. If not just try to bump it down a little.
Old Aug 25, 2004 | 10:40 PM
dzzy's Avatar
Get your cable adjusted properly and set idle speed. If that doesn't do it, a subtrans shift fork is probably bent.
Old Sep 16, 2004 | 09:36 AM
RobertH's Avatar
Did you ever figure out the problem? I have the same thing happening when going into reverse but not drive.
Thanks, Rob...
Old Sep 16, 2004 | 11:35 AM
therock's Avatar
Not Yet,
The Rincon has not been ridden since I posted. I just called and hounded him about it. I'll report as soon as I get the word.
Reactant
Mar 30, 2022 02:08 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
Scottma518
Jul 10, 2015 12:42 AM
bikedad3
Jul 2, 2015 02:15 AM
