get 13 or 14 tooth front sprocket for 400ex?
Down 2 teeth on the front sprokcet is a lot...where are you riding? Down 2 teeth on the front would be like droping down to a 15 inch rear sprocket ruffly. Your topend will die. I'me urnning 18 inch tires with stock gearing which is just a little taller then drop 1 tooth. I hate that my top end is down so much but its not that bad because I dont use the wide opn all the time i'm usually in 4th wide open on the track. I wouldnt recommend going to a 13
