Things to look for when buying 3 yr. old 400ex?
Old Oct 13, 2004 | 11:19 AM
96lapiscoupe's Avatar
Default Things to look for when buying 3 yr. old 400ex?
I need something else for harescrambles racing, and I'm going to look at a few used 400ex's soon. Is there any weak spots on the frame to look for, any common failure points on the 400ex if I pick up a used 01 or 02 model? Just looking for ideas. Thanks.
Old Oct 13, 2004 | 11:48 AM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
I would just check for play in the bearings, if it is running smooth. A-arm scratches can tell somewhat what kind of wear it has unless it has been repainted. The ex's are pretty solid so there reall isn'e anything to look for weak spot wise.
I also wouldn't buy anything with engine work done to, that usually means it has been ran hard.
But evertything I stated above can be disregarded if you find one dirt cheap.
Old Oct 13, 2004 | 11:44 PM
TractorPacker's Avatar
Do you have a balloon?
I would rather have Downs than a '99 400ex. That is the opening year and seem to have a lot of problems. There are so guys who disagree with that, but its what I have seen.
I don't know of any problems to look for other then the allready stated bearing check.
Old Oct 17, 2004 | 12:46 AM
SuzukiOzark's Avatar
check the front wheels and axle for play. if there is any play plan on replacing the bearings. if it still has stock tires, its pretty easy to tell how much it has been used.
Old Oct 17, 2004 | 12:54 AM
CroBiker's Avatar
ride it. 400EX has an issue with the first and second gear going out when they are abused and used constantly.
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
Frisky2050
Apr 9, 2020 11:19 AM
toonces
Oct 16, 2019 12:11 PM
Mphillips
Jul 2, 2015 07:20 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
