440ex jetting of stock carb HELP
Old Oct 30, 2004 | 07:09 PM
  #41
440LW's Avatar
Default 440ex jetting of stock carb HELP
Ok ,thanks buddy !!!
440LW
Old Oct 30, 2004 | 10:02 PM
  #42
Ozark38's Avatar
Originally posted by: 440LW
Im just going by free reving the motor ,with no load on it .
LOL! Its going to be pretty hard to tell just where your jetting is if you can't ride it.............[img]i/expressions/face-icon-small-smile.gif[/img]
Maybe you should have it dyno-ed.
Old Oct 30, 2004 | 10:45 PM
  #43
440LW's Avatar
Yea ,this absolutly SUCKS not being able to ride !!!!!!![img]i/expressions/face-icon-small-mad.gif[/img]Im gonna miss flat tracking at our local indoor arena. Oh well...What do ya do ???!!!I probably will just have it dynoed .
440LW
Old Oct 31, 2004 | 02:48 AM
  #44
cals400ex's Avatar
on my 11:1 426 with the air box lid on and at 625 feet above sea level i run:
keihin 158 mainjet
4th needle clip position
42 pilot jet
approximately 2.75 turns out on the fuel screw
Old Oct 31, 2004 | 11:43 AM
  #45
440LW's Avatar
Ok ,Ill go ahead and give that a try .So top end is pretty good w/that 158 main ??
440LW
Old Nov 1, 2004 | 03:09 PM
  #46
cals400ex's Avatar
the smaller you go, the more top speed you will have. just don't go too small so you fry your engine. the more motor you have doesn't always mean a larger mainjet. however, more fuel can be pulled through that same mainjet sometimes because of the more powerful motor.
Old Nov 1, 2004 | 06:46 PM
  #47
440LW's Avatar
Geez...Im learning new things every day .Ill try that ,just go down a size at a time ,and see which one gives me the best performance .
Thanks alot,
440LW
Old Nov 2, 2004 | 04:03 PM
  #48
wildcatkit52's Avatar
Most common mistake people make is that they need to go so much bigger... Most things you do to make anything just a little better than stock will more than likely be happy with proper jettings on a stocker for your area. Your engine doesn't like too much gas just like it doesn't like to little...
Old Nov 4, 2004 | 07:56 PM
  #49
polarsport500's Avatar
if you are going to leave your airbox lid off after putting in the 440 kit would your jetting change? or would it be around 158 as well
Old Nov 5, 2004 | 12:10 AM
  #50
Ernie660R's Avatar
45pj, and a 168mj to 172mj
