440ex jetting of stock carb HELP
Old 11-05-2004 | 12:50 AM
polarsport500's Avatar
Default 440ex jetting of stock carb HELP
thats for without a lid?
  #52
Old 11-05-2004 | 11:51 AM
Ernie660R's Avatar
Thats correct Polarissport500, without a lid......[img]i/expressions/face-icon-small-smile.gif[/img]
  #53
Old 11-05-2004 | 09:20 PM
cals400ex's Avatar
with a 440 and no air box lid i would run around a keihin 160 mainjet. this is for around 600 ft above sea level and around 70 degree temps. however, the temperature and altitude you live at matters a decent amount. the cold months make the air more dense, thus you get more oxygen from the air. in turn, you need to increase your jetting. the same goes for altitude. the higher you go, the less 02 in the air so you need lower your jetting and vice versa.
  #54
Old 11-11-2004 | 08:29 PM
440LW's Avatar
Hey this is 440LW again .I was just out zipping up and down the driveway ,and it's running alittle rough .The last time I had it out ,it was about 55 degreez ,now the temp had dropped to 45 .it is backfiring alittle ,and running kinda rough on the bottom end ,almost like it is not getting enough fuel (blubbering)<then you hit the gas ,and it back fires .Should I go from a 42 pilot ,to a 45 ?My air screw is out about 2 1/3 turnes.My main is a 172 .What do ya think ??
Thanks
  #55
Old 11-14-2004 | 03:37 AM
cals400ex's Avatar
if it is backfiring when you let off the gas, you need to turn the fuel screw out a bit.
  #56
Old 11-14-2004 | 12:15 PM
440LW's Avatar
Ok ,thanks.Ill try that .
440LW
  #57
Old 11-22-2004 | 12:37 AM
440LW's Avatar
Hey ,I was wondering if you are really familiar with the stock 400ex carb ? If so , is the float baffle supposed to fit really sloppy over the main jet ,or should it be really snug ?I believe it is messing with my float level ,because it keeps falling down twards the bottom of the bowl ,it is VERY loose sliding over the main .
Thanks,
440LW
  #58
Old 11-22-2004 | 03:36 AM
cals400ex's Avatar
are you talking about that little plastic pinkish colored piece that slides over the mainjet? if so, it won't be on there really tight. it just slides on. there is only one way that piece can go on properly too.
  #59
Old 11-22-2004 | 09:39 AM
440LW's Avatar
Yea ,that is the piece that Im talking about . So ,if it's supposed to be loose ,then it is fitting properly .
Thanks a lot !!!
440LW
  #60
Old 03-06-2010 | 04:40 PM
2007rhino's Avatar
Question my 2004 400ex wont start
i have a 2004 400ex that i bought blown up so i bought a 440 rebuilt kit i put it all on did the timing its perfect i have fuel spark compression etc it will not even try to start is there something i missed please help!!!!!!!!
Firefighter400
10-08-2022 06:38 PM
Cole Hadden
08-24-2020 11:11 PM
Reactant
07-16-2015 10:29 PM
Dirtbikemike1
07-11-2015 03:36 PM
cSchwartz
07-09-2015 02:43 PM
Quick Reply: 440ex jetting of stock carb HELP
