Rear break light
Old Sep 1, 2000 | 02:25 PM
boots11234's Avatar
Is their a kit that I can install to hook up a rear break light for my Rubicon?
Thanks
Old Sep 1, 2000 | 02:37 PM
hiofcer's Avatar
I sure would like to know that as well. That's the only thing I wish Honda would put on their machines. Otherwise I'm completely happy.
Did anyone happen to notice a clicking sound when you apply the front brakes on the Rubicon? It souunds like a switch. At first I thought it was for a brake lights but no such luck.
Old Sep 1, 2000 | 02:42 PM
TEXMud's Avatar
The click sound on the righthand lever is the switch for the start in gear feature. That lets you know you pulled the lever far enough.
Old Sep 1, 2000 | 03:05 PM
TxDoc2's Avatar
On the 300, it came from the factory with mounting holes for a brake light kit. But, the 500 does not have the same setup and the microfiche does not show it as an option. They may come out with a kit or the kit for the 300 may be able to be altered to work. Hope that helps.
Old Sep 1, 2000 | 03:07 PM
tempest's Avatar
I am not sure about the Rubicon but there are kits from Honda for the Foreman and Rancher.
Temp
Old Sep 1, 2000 | 09:52 PM
JWCTRX's Avatar
Tempest, can you tell me where to find brake light kits for the Foreman? I checked Honda web site and couldn't find anything on parts at all! Thanks, JIM
Old Sep 2, 2000 | 01:28 AM
azrob's Avatar
If I can install a brake light on my 400EX then you should have no trouble installing one on your Rubicon. Buy one standard brake light switch (less than $10.00) and simply use a tie strap to hold the switch when you depress your rear brake pedal. Then simply wire it up.
Old Sep 2, 2000 | 08:38 AM
tempest's Avatar
Jim, I will check with my dealer and get the part number for you.
Temp
skinnyr6
Aug 25, 2023 02:18 AM
greg74
Sep 10, 2019 03:03 PM
JoAnnS
Jul 23, 2015 02:18 PM
clsharky
Jul 13, 2015 02:07 PM
rcappie4
Jul 10, 2015 04:54 PM
