Bars for TRX 450R
Old Dec 29, 2004 | 03:01 PM
CoyoteRiverRaptor's Avatar
Default Bars for TRX 450R
We put the Trail Tech mount and bars on my sons 450. We went with the high bend which raises the bars about a 1/2" over stock. It is perfect, even came with a plastic cover to hold the key switch and oil light.
You will have to lengthen your front brake line though. I've been told if you go with the med bend you don't need a longer brake line.
The high bend is perfect!
Old Dec 30, 2004 | 01:51 AM
Rcpilot's Avatar
Ok thanks I check them out
Thanks Tim
Old Dec 30, 2004 | 09:42 PM
Trx440's Avatar
Longhorn cr high and Longhorn big bar adapters. $75 total from Rocky Mountain ATV. they are just a bit lower [ bout a half an inch] than stock with less pull back.
If you want a higher bar get the Longhorn adapters for $34.99 and a set of Renthal Fat bars in the Charmicheal high bend for $49.99. They are about an inch higher than stock I was told.
Rocky Mountain has them both.
Old Dec 31, 2004 | 02:41 AM
Rcpilot's Avatar
Thanks I will check them out
Thanks Tim
Valder
Nov 28, 2020 07:38 AM
wendal
Sep 7, 2019 06:46 AM
badgerboy1
Sep 26, 2017 06:11 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
PrairieDog126
Sep 12, 2015 05:23 PM
