Bigger carb on a Recon 250?
ReconBayou said it all.
check your plug
black=rich
White or gray=lean
Brown = good
Always check at wide open throttle.
I have a pdf file that explains how to check the carb at idle, 1/2 thottle, and wide open throttle but I don't see where I can send an attachment. Sorry i'm new to this forum let me know if there is a way to attach files and I'll post it for ya.
check your plug
black=rich
White or gray=lean
Brown = good
ill take you up on that file. you can send it to Kruserdodge60@mail.com if you can. that would be greatly apreciated!
Ok I sent you the pdf file that I have but it's not exactly what I meant to send you. I can't seem to find it. I'll keep looking but I did find something very similar. I think the first link is the same info that I have somewhere on file. The second one is pretty much the same but very informative. The third kind of explains how things work. You should read all 3 before you start the re-jetting process.
Hopefully this will help out.
http://www.all-offroad.com/DirtBikes...s/BGNov98.html
http://www.motorcyclecruiser.com/tech/jetkit/
http://raskcycle.com/techtip/webdoc12.html
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
