1999 recon
i find them a bit cold blooded (run a little rough cold, but purr once warmed up). a 5-6 y/o unit like that should have had a valve adjustment or two. no hour meter or speedo, so actual use is hard to pin down. check to see if they're orig tires or replacements. if orig tires, maybe use is under 2000 miles. replacements... who knows?? shake front wheels to make sure there's no excessive play. they are a pretty reliable, bullet proof quad.
Steeldon
Sep 9, 2015 09:38 AM
