Rubican and Warn 424
hey tools found mine on e-bay under honda rubicon parts good price $240.00 delivered .wasn't to hard to install about 2 hours the only thing was is where to put the lever .I drilled a hole in the front fender then bolted it on as for how i like it it's alot diffrent can turn on a dime and it dosnt spin the tires like i thought it would.maybe because i built a homade droprack for it maybe around 50lbs or so
I have had my 424 for 2 years. It is a great addition for the Rubicon, makes for a sportier ride easier steering and less tire wear. The 424 is very well made and pretty easy to install. Get one you won't regret it.
I have gotten by with removing the **** and hardware, and slipping it through the fender via front rack hole. And saved drilling into the fender. Some cases, the rack has to be removed, the cable routed into the fender rack hole and the rack reinstalled.
----- gregg -----
----- gregg -----
The 424 has to be the best thing that I've put on my rubicon. I also think that Honda should consider having a system to do so on every 4x4 atv's they have on the market. they have it on some models, why not have it on all of them?
Jeff Roper
Feb 1, 2022 11:48 AM
