Foreman ES not shifting
Old Jan 21, 2005 | 09:47 PM
01HondaRecon250's Avatar
Default Foreman ES not shifting
hey guys,
i have a queston... today my dad was going to take the foreman out, started it and it wouldnt shift with the es... it was like 5 or 10 deg. out. any ideas, did this happen to anyone elese?
thanks
tom ford
Old Jan 22, 2005 | 05:05 AM
confusedbuyer's Avatar
usually, you'll get a bunch of blinks on the first gear indicator, anywhere from 1 blink, to 12 (?) the number of blinks can then be referred to a trouble shooting chart to tell you what it is. I'm not sure with the foreman, but on the recon, it's often the angle sensor. BUT what it really ends up being quite often is loose or dirty connections. On my recon i was getting the angle sensor code. the first thing the manual tells you to do is check and clean the connections.I'd try that first. unplug the wiring harness at the ECU (elec. control module, blow out the dust, add some silicone di-electric grease (it's like vaseline), then firmly push it back together. try the same at the angle sensor. once plugged back together, i wrapped mine with duct tape to keep it together, and to keep dust out.
ALSO, check battery connections, and make sure battery is charged. could be weak battery. I'm guessing with your cold weather, it might be that, altho i guess it wouldn't have started if the batt was too weak.
Old Jan 22, 2005 | 09:26 AM
the foreman is new... got it a few weeks ago
i rember it was blinking... the gear indicators... it shifted fine with the manual shifter
tom ford
Old Jan 22, 2005 | 11:19 AM
hondabuster's Avatar
When it is really cold out, my 03 doesnt like to shift really reliably until it warms up.
Is it working now?
If you use the foot shifter, it will keep the es part from working until the key is turned off and then back on.
Old Jan 22, 2005 | 11:44 AM
orky4969's Avatar
get new battery. had to do that to my friends. also if that dont work clean all your connections as some one stated above.. because that also happend to my other friend... we had to unplug everything *in the back especially* and blow out dust.water.etc. and it worked again*
Old Jan 22, 2005 | 05:15 PM
if we start it and try the es it wont work but let it run for like 5-10 min and it's ok.... we love the foreman.
thanks guys
tom ford
Old Jan 22, 2005 | 07:49 PM
When mine was doing that, I did the clutch adjustment and it got much more reliable when cold.
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
