Puttn on new tires...how do I break the bead?
All tools are different...just because some of Harbor Freights tools are great doesn't mean their ATV bead breaker doesn't suck. Changing ATV tires is easy, breaking the beads can be a real challenge. I agree with d33pt. I've changed thousands of tires in my life, I have the knowledge. But if I didn't have the proper equipment, I'd bring 'em in.
I got my tire changer from James Lucky and have used it at least 20 times and it is still the same as when I bought it. There is one big trick though...you need some weight pushing down on the opposite side you are trying to break the bead on. I always shove the edge of the tire under the side of a car. A big guy standing on it would work too.
It would be a snap if you had one of the bead breakers that mounts to the garage floor.
Once you break the bead, 3 tire spoons make it the easiest to get the tire off.
I've had to change tires at the trailhead several times. Can't imagine being without this tool unless you keep spare rims and tires.
/Jon
/Jon
I have a bead breaker from HF. It has worked good on all the car and atv tires except for my Kodiak's. It wouldn't break them from the rim. We then tried them on one taht a buddy has and still wouldn't do them all. We had to wind up cutting 2 of them off the rims. It took a long time and sucked!
Originally posted by: charlieborg
Hey you all. I got me some nice tires for my Honda Rancher (2004 400 at). I tried to get the old tires off by layn them down and running up on them with my truck tire(valve stem removed). This works on car tires, but no luck on ATV tires! Are the ATV BEAD BREAKER worth getting?.....() link to one
#15
I tried to break the bead off of my Banshee rear stockers and It Sucked. I finally broke down and took them in to a local shop but Im getting the tire changer on the Harbor freight site. I can weld good so if it breaks I'll make it better. Cost me 20 bux for them to take them off and put new tires on. I'm not afraid of alittle work.
#17
#18
Hey, I just had a brain storm....I got a hydrolic wood spliter from my grandfather last year, wonder if it could be modified to break the bead on a ATV tire...[img]i/expressions/face-icon-small-happy.gif[/img]
