2000 honda recon 250
its tricky. Ive done it twice.. you need a torch to heat it up (weve done it till its glowing) then u need to stand by with a good strong flat head screwdriver and hammer and kinda knock it out. or sometimes, we had to use a "wiz wheel" and actually cut thru the outer bearing, then heat it up and beat it out.. its tough..good luck
mark
mark
tank10rnk
08-10-2015 08:19 PM
