400ex upgrades piston, cam, etc
i have a 01' 400ex and i need to replace the piston rings...i figured while i was in there i would do some upgrades....thought about an 11:1 stock bore wiseco piston and a cam...either the white brothers all around or hotcams stage 2....also plan on replacing the header pipe with an fmf (hi flo or power bomb)....thought about a 440 kit but i want to remain reliable and don't want to spend that kind of $$$.....
it already has a white brothers e-series slip on, rev box, k&n, and jet....i mainly ride trail and track in the midwest
the question is....is anybody running this set up or something similar??...and how do you like it???
If you go with 11:1 I would go with a 426 ROSS or JE piston with Hot Cam 2 . I had a 426 all this year on mine and loved it.Also porting will be a nice enhancement.the Cost wasnt that much different and a 440 can be as equally reliable if you do the job right the first time and it runs cooler.....
I decided to go a new route and do a 12:1 Full Duncan 440 kit this time with a 450R carb . either way I have a jug for both and Ill have my 426 if I ever needed to fall back on it, butanyhow, if your mods are done right you will be very pleased...[img]i/expressions/face-icon-small-smile.gif[/img]
Tina
Tina
The link below was from an earlier atvconnections forum post (my http link above didn't have the correct text [img]i/expressions/face-icon-small-sad.gif[/img] The page includes dynos comparing the 450r carb on a 400ex (it is actually a 416, but the gains should be relevant?). A 4hp increase is shown with the upgraded carb:
http://www.trx450r.org/forum/index.p...=4150&hl=400ex
The original atvforums thread is here:
http://forums.atvconnection.com/mess...did/438399.cfm
