Axle nut comes loose...
Old Oct 2, 2000 | 10:15 PM
hondatrx300ex's Avatar
well I am puttin new bearings in mine...... the sprocket and disc hubs do have some very small grooves in them.... I hope I'm don't have any probs with my axle nut coming loose after this.....I'm gonna go ahead and put some locite on it....so maybe I won't have any problems.....later
Old Oct 2, 2000 | 11:07 PM
tprender's Avatar
On the Honda after you take the nuts louse the first time, they will never stay tight again. You will have to use some kind of tape over the nuts to keep them tight. Locite tight will not work by itself. aand, after you do the stock nuts on and off a few times the nut will jump on the collar. If you take a dial calipor and measure the size of the male portion. You will find the top of the threads at the end is a different size than in the middle. A quick fix is to turn the collar around and use the other side for a few times, before they wear down. The Dura Blue set-up will wear down just like the stock does. The RAD system will work very good. The reason that the anti-fad works so well is because of the corse thread being very deep. But the system is very costly(about $250). We have tried all of the different systems in over 10 years of racing and if you have the money, buy the anti-fad. If not, get the RAD system for about $50.
Old Jul 9, 2020 | 04:52 PM
Brian Lawrence's Avatar
Originally Posted by BUBBAG
I JUST BOUGHT THE RADS FOR 50$ AND AM VERY HAPPY..THE SALES DUDE SAID THE DURABLUES ARE JUNK, THE ONES THE COME WITH THE BRAKE CALIPER HUB, THAT COST AROUND 200$ SO DO YOURSELF A FAVOR AND GET THE CHEAPER AND BETTER RAD LOCK NUT
Where did you buy Radloc? I need them for Honda 300 4x4
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
1000gade
Sep 9, 2015 04:41 PM
bmark0610
Sep 7, 2015 09:42 PM
snowolson
Aug 31, 2015 03:51 PM
toonces
Aug 5, 2015 05:55 PM
