Air scoops... DO they really work? HOTT Motor!!!
Old Mar 21, 2005 | 07:37 PM
wheelinforlife's Avatar
Default Air scoops... DO they really work? HOTT Motor!!!
My engine has been running more hot than normal. I went riding today and it was only 38 degrees and the motor felt really hot. Do you think I'm losing it or is yours like this too??? And will air scoops help me at all? And are they easy to install. thanks
Old Mar 21, 2005 | 08:02 PM
Vinson581's Avatar
air scoops do help.
and btw there is no radiator on a 400ex, it is a air cooled bike
what is your jetting at?
v581
Old Mar 21, 2005 | 08:04 PM
I would not dout it. How can I tell should i check my plug? i have a HMF slip-on, 165 jet, K&N filter, i have not done anything with the air-screw and the needle position. I'm not the best with mechanical stuff. How hard would it be to put my needle down one?? thanks for all your help people!
Old Mar 22, 2005 | 12:22 AM
Also how hard is it to take your carb off?
Old Mar 22, 2005 | 02:26 AM
HA2's Avatar
HA2
its not hard at all. sounds like you need to adjust your jetting for the temperature only.
Old Mar 22, 2005 | 06:30 PM
flynhi250r's Avatar
V581 a 400EX is air cooled and does not have a radiatior like you said but it does have an oil cooler and this helps a great deal in cooling the engine. The scoops send more air to the iol cooler.
Old Mar 22, 2005 | 06:44 PM
400eecksRider's Avatar
air scoops help, plus they are a cool place to put more stickers.
Old Mar 24, 2005 | 02:04 AM
cals400ex's Avatar
the engine builders that i have talked to said don't spend the money unless:
1. you need a place to hold stickers
2. you like the looks of them
they said oil coolers do help though (like the FST cooler), but it isn't anything extremely drastic.
Old Mar 24, 2005 | 09:39 AM
Vinson581's Avatar
i know the 400ex has that little finned oil cooler, but where the air scoops mount the air isnt directed on them, and is directed on the head of the motor.
the fst oil cooler is nice, but shouldnt be needed, and you also have to tap the head of the motor for it to work, something i dont reccomend doing unless you have the proper tools.
i think scoops help, but as said only if your moving in a straight like, because of the way the air moves. for 40$ i think its worth it.
v581
hugemoth
Jul 20, 2020 03:28 AM
Mphillips
Jul 2, 2015 07:20 PM
bikedad3
Jul 2, 2015 02:15 AM
momofo
May 27, 2015 12:06 PM
JackOReilly
Dec 7, 1999 09:12 AM
