Is it ok for a 400ex to smoke lightly when you rev it then let off the gas?
Old Oct 4, 2000 | 10:42 AM
  #31
nightlife7810's Avatar
I agree with Gabe on the Mobil 1 15-50 fully Synthetic. I have run this for several years. Four Stroke Tech recommended it in my old warrior when they worked on it and the oil worked great. So when I got my 400 last year I put the same oil in it and have ever since!! Never see smoke with my 440 kit.
Old Oct 4, 2000 | 11:47 AM
  #32
1QuickEX's Avatar
Are you guys using regular mobil 1 car oil? Why does Web-Cam recommend using non-synthetic oil with their cams?
Old Oct 4, 2000 | 12:22 PM
  #33
I use regular Mobil 1 - I have a web cam and have never had any probs. I didn't know that they didn't recommend this oil at the time. I hope everything will be alright - does anyone know why they don't want synthetic with their cams??
Old Oct 4, 2000 | 02:58 PM
  #34
86atc250r's Avatar
Best guess I got is that they are subscribing to an old myth of synthetic oil.
The camshaft in your atv is no different than that of an automotive engine, if synthetic oils caused problems with automotive camshafts (sometimes up to 4 per vehicle) synthetic oils could not exist in the marketplace.
Old Oct 4, 2000 | 03:01 PM
  #35
86atc250r's Avatar
Walmart in our area is running a sale on Mobil1, $3.50/qt... Stock up...
Old Nov 25, 2003 | 12:08 AM
  #36
pungohboy's Avatar
Default Is it ok for a 400ex to smoke lightly when you rev it then let off the gas?
Hey guys i read this post earlyer today and went to walmart and could only rember 20w50 I ended up getting castrol syntec blend 20w50 is this stuff ok to run in my 400ex. it says nothing about working with clutches. my 400 started smoking while warming up and i am hoping this will help. also i have always heard with cars you should stick wiht one brand of oil. does it matter with atvs and also i have heard dont go to synthetic then back to normal oil will this effect anything. thanks. oh yea this stuff is part synthetic.
Old Nov 25, 2003 | 12:09 AM
  #37
pungohboy's Avatar
Old Jun 15, 2011 | 06:14 PM
  #38
06400ex's Avatar
hey my 2006 400ex smokes when its could but when its warmed up it smokes very very little or not at all when i bought the person who had it overfilled it with oil i drained a little the same would that be sign of needing valves adjusted drain the oil and put something thicker in or is it good to go
XxS0ccerstarxX
Oct 18, 2021 10:03 PM
Cummins Driver
Sep 11, 2019 01:22 PM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
metal249
Jul 28, 2015 09:35 AM
