Bad back breaks!
Old Apr 15, 2005 | 12:45 AM
wheelinforlife's Avatar
Default Bad back breaks!
On the 400ex sounds terrible when i use them! How easy is it to fix this and what do i do? It seems like they are getting weaker.
Old Apr 15, 2005 | 08:05 AM
ZimRaptor's Avatar
hmm lets see...REPLACE THE PADS lol
Old Apr 15, 2005 | 02:48 PM
NotuRaptor2's Avatar
1) Acquire new pads
2) Loosen but do not remove 2 bolts that hold the pads in place. You will have to bend the 2 tabs out of your way so you can get a 12mm socket over the bolts.
3) Loosen and remove 2 bolts that hold brake assembly to the swingarm
4) Remove the first 2 bolts that hold the pads in place
5) Use C-clamp or c-clamp vise grip to push the hydraulic cylinder back into the brake rotor
6) Push the other movable piece on the opposite side of the hydraulic cylinder back.
7) Install new pads and 2 bolts removed earlier.
8) Install 2 bolts to hold brake assembly to swingarm and torque to 22 ft/lbs
9) Torque the 2 bolts holding the pads to 12-13 ft/lbs.
All done.
Old Apr 15, 2005 | 04:31 PM
Ok thank you NotuRaptor2 that was helpful unlike zim raptor.
Old Apr 15, 2005 | 08:04 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
You may need to replace the disc too if it is badly gouged from the pads wearing out.
Old Apr 15, 2005 | 09:23 PM
TractorPacker's Avatar
Do you have a balloon?
Originally posted by: NotuRaptor2
1) Acquire new pads
All done.
Wow put that in brail and a blind guy could do it. Very good directions.[img]i/expressions/face-icon-small-cool.gif[/img]
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
skinnyr6
Aug 25, 2023 02:18 AM
Reactant
Mar 30, 2022 02:08 AM
Frisky2050
Apr 9, 2020 11:19 AM
Coryco
Jul 6, 2015 07:30 PM
