99 foreman 400 clutch adj??
Old May 4, 2005 | 09:23 PM
jesskidoo's Avatar
Default 99 foreman 400 clutch adj??
reading in the manual it shows a pocedure to adjust clutch play so i did it, turned screw till felt resistance then backed off 1/4 turn and tightened er down. K so heres the question, Shifting now seems to be alot stiffer and sometimes seems impossible to shift up. Does a guy back the screw off till shifting is where i want it to be? How far(looser) can a guy go to be safe? What should it feel like? What advantages are a stiffer shift if any? thanks all just picked up this machine for her to ride and needs to be an easier shift!! Thanks again!
Old May 6, 2005 | 10:51 AM
jesskidoo's Avatar
Can anyone help me??
Old May 7, 2005 | 05:46 AM
confusedbuyer's Avatar
they are a bit of a stiff shift. I'd think ya can loosen it a little. I don't know the answer to your Qs. Only a guess that too loose could strip or slip.
Old May 7, 2005 | 11:25 AM
hondabuster's Avatar
Seems to me there is an arrow and some writing on the case, right by the screw. But anyway, you can try experimenting and go a bit beyond 1/4 turn, but this adjustment is really only adjusting the free play in the unit. The clutch engagement is gonna be a bit abrupt, its kind of on or off...it isnt like a manual clutch where it can slip a bit , or where you can control the release speed.
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
